R.LAB data recovery
January 26, 2021, 06:12:36 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: HDDScan gets stuck before showing window  (Read 8156 times)
JDlugosz
« on: October 31, 2014, 09:19:06 AM »
When I launch the program, no window shows up.
Looking at the stack:
Code:
USER32.dll!SystemParametersInfoW+0x40
HDDScan.exe+0x2235da
It appears that the call to
Code:
SystemParametersInfoW (SPI_SETNONCLIENTMETRICS, sizeof(NONCLIENTMETRICSW), &local, 0)
(structure size indicates WINVER is Vista or higher)
Some Google searches don't show any answer as to why this function would hang when the last parameter is zero, other than malformed contents of the passed structure.  There are a number of posts similar to that complaining about calls to
Code:
SystemParametersInfo (SPI_SETNONCLIENTMETRICS,
intermittently not working on Windows 7, but that's all I found.
It's a shame since setting the theme is not something that affects the core functionality of the program.  In fact, I don't like crazy themed windows in general and prefer normal controls.  But, it looks like I need to find another program to run SMART tests on a new drive.  Perhaps the point made for SystemParametersInfo in general of always running it on a scratch thread (although with the last param being zero it should not have needed that) is a good idea if this function is cranky.
Logged
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
